Need chassis welding help! Seam welding unibody w/ TIG
Old Sep 17, 2023 | 07:16 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Default Need chassis welding help! Seam welding unibody w/ TIG
I am seam welding my 05 focus 4 door, and don't have MIG. Only TIG. I have cleaned the metal pretty well, but not well enough, bc I cant get between the layers that are spot welded together. Tried quick pass w/ no filler to burn a bit off, clean w/ 99% iso or acetone in between passes, but still getting too much contamination. Using 70s-6 filler.
Can I drop a little muriatic acid on the seam to clean up the inaccessible seam? Or can I use flux core wire w/ a TIG torch? lol
Help! Gotta finish this before I can drop the motor in. Pics are after quick passes over everything w/ no filler to burn off a little. Still getting contamination bubbles.
Old Oct 10, 2023 | 11:46 PM
chidog's Avatar
Default Re: Need chassis welding help! Seam welding unibody w/ TIG
What polarity are you using? Just argon? Looks a bit cold?
Mishako129
Aug 22, 2012 04:46 PM
iBrandon
Welding / Fabrication
Feb 29, 2008 06:39 PM
used2baracer
Jul 23, 2005 08:38 PM
dopeydavid
May 14, 2004 12:42 PM
sinatra
Jul 29, 2003 10:03 PM
