no cylinder 3
Old Sep 17, 2023 | 05:45 PM
cameronlucas's Avatar
Default no cylinder 3
need help. i recently picked up a 91 crx si thats been d16y8 swapped. cylinder 3 is not working. compression was great at 190, new plugs, and injectors are working without issue. im running obd0 distributor, ecu, and injectors. any idea what the problem is?
Old Sep 19, 2023 | 02:44 PM
Smackin's Avatar
5 Year Member
Loved
Community Favorite
Default Re: no cylinder 3
190psi seems high. That's good though. How do you know the injector is working? Do you have spark on cyl 3?
Old Sep 21, 2023 | 06:48 AM
kraquepype's Avatar
10 Year Member
How are you determining that #3 is not working? Are you getting spark on #3? If not, check the distributor cap and the plug wire resistance.
If there is spark, next thing I'd do is verify timing, and then a leak down test to rule out any valve issues. Has the valve lash been checked recently?
captn38
Mar 5, 2013 12:54 AM
VXvtec
Oct 27, 2012 09:47 AM
magic hat #9
Sep 19, 2003 08:23 AM
g5r
Sep 4, 2003 06:04 AM
SEFIxCivic
May 14, 2003 07:58 AM
