Front of Car raised up, moving front driver wheel makes sound
Old Sep 11, 2023 | 03:28 PM
lurice01's Avatar
10 Year Member
Loved
Community Favorite
Default Front of Car raised up, moving front driver wheel makes sound
I have the front of the car jacked up and i pull on the drivers side wheel and it goes tick. The passenger side doesn't.
Carefully watch videos, i can get it to make the noise with hands at 12 and 6 on wheel or 3 and 9 o'clock on wheel.
The inner and outer tie rods are new. The axle boot is torn but they're not clicking yet.
what is the source of the noise?
https://youtube.com/shorts/jsP_ip9wQIY?si=dz1a8Fpa_OKnT2CP
Old Sep 11, 2023 | 03:30 PM
lurice01's Avatar
10 Year Member
Loved
Community Favorite
Default Re: Front of Car raised up, moving front driver wheel makes sound
Another video of same issue
https://youtube.com/shorts/Bazlbwrxm...LeQ0F91OZQhoMy
Old Sep 12, 2023 | 05:37 AM
lurice01's Avatar
10 Year Member
Loved
Community Favorite
Bunp
Old Sep 14, 2023 | 05:02 PM
xxstuntin4life's Avatar
double check all the bolts are tight, also take a close look at the upper control arms, a lot of times the rear bushings blow out and can make a clunk like that
Old Sep 16, 2023 | 12:31 PM
Matt Richardson's Avatar
5 Year Member
I would remove the wheel and wiggle individual suspension parts to see if you can isolate it. If you can't find any worn bushings or lose bolts then it could be your wheel bearing, if it's out the wheel will wiggle a bit in and out when you pull on it like you were in the video.
Old Sep 17, 2023 | 06:07 PM
lurice01's Avatar
10 Year Member
Loved
Community Favorite
Thanks yea it was loose upper control arm bushing bolts sorry
jdmem205
Dec 24, 2012 08:59 AM
o0Jash0o
Sep 28, 2006 09:22 AM
sf89lx
Aug 26, 2004 10:05 AM
green98civic
Dec 11, 2003 10:26 AM
Sephro
Oct 11, 2002 10:34 AM
