92 Prelude h22a4 swap
Old Sep 7, 2023 | 10:09 AM
theoryh's Avatar
Icon5 92 Prelude h22a4 swap
Got a dirt cheap 92 prelude si . i want to say its been swapped , now has a h22a4 motor in (is this motor a obd2 style motor.??) i been trying to figure out and research everywhere about the swap i currently have no spark , i believe has to do with the swap and no fuel , but the pump does fire up with direct power . just not with the actual ignition. (swapped relays in my civic to the prelude and no change ill rule out the relays are OK) Found the car had a viper immobilizer on it ripped all the wires out unhooked everything . Could it be something from the immobilizer cutting the pump and spark from distributor ? Dont see any extra spliced wires or shorts but i need a wiring diagram or if someone has done similar swap guide me thru
Kylecolten1017
May 16, 2016 09:27 PM
Sleepythecivic
Classic Hondas
Dec 24, 2012 04:11 PM
Honda_RN
Jan 11, 2006 11:13 PM
Digitalcivic
Oct 10, 2002 11:35 AM
