👋Hello all of my Honda Fans 🤜🤛 bmxa trans help
First off if I'm in the wrong place with this post please 🙏 forgive me & thank you for all your help.
so long story short I bought me a $400 dollar civic about 6 months ago and have been dumping money Into it every since I bought it however never driving it except into & out of my shop during working hrs. When I drained flushed & changed all the fluids I noticed that the trans fluid was like a pink milkshake and at the time didn't realize it was going to need a rebuild until 350 dollars worth of trans fluid later & flushing it many many times. I finally insured & tagged the car to take it out on the street to drive it which to my surprise the transmission was slipping.
So I brought it back to my shop & immediately ordered a master rebuild kit with all new clutches & steels an upgraded filter a translab shift kit & a new torque converter. I pulled the trans & tore it apart and completly rebuilt it no problems at all. However while still on the jack stands before I put it on the ground I started it to let the fluids run threw the trans and as I was going threw the gears everything shifted fine.
now with my foot in the break "not thinking I needed to bleed the breaks as I went from reverse to park it grinded a little for about 1 second before I went back to reverse then killed the car and put it in park. Not thinking anything of it because it wasn't bad I put the car back together & drove it & it drove just fine & still does.
well the 3rd or 4th time I tried to go in reverse it acted like it was studering going in reverse so out of fear of messing up the new rebuilt trans I parked the car. The next morning at 2am I went back to pulling the trans & disassembling it again where I found metal shavings in the trans. So I tore it completly back down to nothing cleaned it all out put it all back together with a new filter "filter #2" and got it all back in the car filled it up & it drives just fine.
however after the 2nd build I now get a bad squeeking rattling noise in park & neutral, but in reverse & drive it goes away. It still feel a little hesitant in reverse but drives just fine.
I crawled under the car today & found out that the torque converter is what's making the noise.
video link here of me driving the car after the 2nd teardown.
https://youtu.be/39i6jGFx3NQ?si=Inip2RAP3amDOM1W
Video link here of me inspecting the torque converter today.
https://youtu.be/CQawhTyx4ms?si=tQzg5f5jVnFHLOZI
could the torque converter be the only thing wrong with it or what do you suggest? I assume the torque converter was not the greated from the get go as I bought a reman on on ebay for 98 bucks but when I tore the trans apart for the 2nd time there was already a little bit of friction material in there along with the metal shavings. All the gears seem find & the parking paw seems fine I just didn't know if a bad torque converter would cause this stuttering in reverse or do I need to replace the reverse gears & servo arm & floating ring gear as well?
any suggestions would be very helpful.
TIA
Mike
TIA
Mike
could the torque converter be the only thing wrong with it or what do you suggest? I assume the torque converter was not the greated from the get go as I bought a reman on on ebay for 98 bucks. My budget was tight at the time, and I wanted to save money. Although later I came across https://ausscasinosanalyzer.com/casi...otsgallery.com with casino reviews. I found out that they have slots gallery free chips. Now I've won a couple hundred dollars and want to upgrade my torque converter. But when I tore the trans apart for the 2nd time there was already a little bit of friction material in there along with the metal shavings. All the gears seem find & the parking paw seems fine I just didn't know if a bad torque converter would cause this stuttering in reverse or do I need to replace the reverse gears & servo arm & floating ring gear as well?
TIA
Mike
TIA
Mike
Dimas Thor
Apr 23, 2016 10:11 PM
barneybug
11
Jan 12, 2015 09:54 PM
