Honda Accord stalling upon startup
Old Sep 4, 2023 | 10:15 AM
Gorgah's Avatar
Default Honda Accord stalling upon startup
I have a 2000 honda accord ex 4 cylinder. I started having a problem where whenever I started the car as soon as I pressed on the gas the car would bog and die. The car would idle fine. I replaced map sensor, fuel pressure regulator. Cleaned throttle body and checked for vaccum leaks. Now the car is struggling to start and will not idle. Sometimes it will start if I press and hold the gas but as soon as I let off the gas car will die. Within the last year I have changed fuel pump, main relay, distributor and spark plugs. Any help would be appreciated.
Old Sep 4, 2023 | 09:00 PM
LukeM's Avatar
5 Year Member
Default Re: Honda Accord stalling upon startup
That's an awful lot parts you replaced without knowing if there was anything wrong with them. Find a copy of the Helms manual and find the diagnosis flow chart for poor starting.
Old Sep 5, 2023 | 05:08 AM
Gorgah's Avatar
ok will take a look
Old Sep 20, 2023 | 03:18 PM
T40sx's Avatar
I did a motor swap some time ago and had this issue similar. It'd run but wouldn't idle. It was the EGR was stuck open and causing a lean condition. Something to consider.
QuickSilverZ
Sep 30, 2012 05:31 PM
melancholly13
Apr 19, 2007 08:52 AM
maxmk8
Feb 14, 2006 02:13 PM
boyracers
Nov 26, 2003 03:21 PM
