Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2005 Civic fuel pressure
Old Sep 3, 2023 | 03:24 PM
GoHardrGoHome's Avatar
5 Year Member
Default 2005 Civic fuel pressure
I've searched the forum threads and although the information is likely there...I cannot find it!
Can someone please advise where I can connect a fuel pressure gauge to my 2005 Civic to check the pressure. What is the spec for normal pressure?
Thanks.
Old Sep 3, 2023 | 07:22 PM
5 Year Member
Default Re: 2005 Civic fuel pressure
I ended up taking the line off the top of the fuel tank and adapting a hose to connect to my fuel pressure gauge. I've got 45 PSI at the pump. I assume this should be sufficient for the system???
Old Sep 3, 2023 | 07:26 PM
5 Year Member
This is my cousin's car and she says it will intermittently stop running when she stops at an intersection. I had to rescue her today, and it seemed that the car would only start when I held my foot on the accelerator a bit. When it did start running, I had to keep it above 1000 RPM to keep it running. It would not stay running at an idle. I drove it home about 10 miles. When I was driving did not notice any drivability issues or lack of power from the engine. By the time I got home, the engine was running and idling fine. Any thoughts??
Old Sep 3, 2023 | 07:35 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
45 psi is low for a dead head system.
Old Aug 6, 2024 | 09:28 PM
EchosBeaming's Avatar
did you ever find out what it was my car is having the same issue currently and I've bought an a/f sensor, a map sensor, a egr valve, idle air control valve to get rid of misfires and now it only does it under 1000 rpm and I have no clue why, I'm going to buy new plugs and I hope that helps, but if you figured this out I'd really appreciate knowing what you did to fix it
Old Aug 7, 2024 | 06:01 AM
5 Year Member
It was a while back but I believe it was a stuck EGR valve. Cleaned it out and freed it up and the car ran fine afterwards.
The owner has since retired the car....417,000 kms and the motor finally said, "I've had enough". She came to the yard with a miss fire. I did a ignition system check...OK. Fuel injector was working fine. Compression check showed a bit more than 50 PSI on all but No. 1 cylinder! No. 1 did not have any compression. I thought I might get lucky and find a broken valve spring or something, but no. Looks like the rings were broken. She decided to buy another vehicle.
Let me know if cleaning the EGR valve rectifies your issue. Good luck.
89hbcivicguy
Mar 17, 2005 01:55 PM
_jester_
Aug 10, 2003 10:26 AM
ProjectCRXtacy
Jul 15, 2003 03:20 PM
