Can I use 15in rims with 15in rotors?
I am looking to swap a big brake kit into my Civic but the rotors from Spoon are 15in. Would I need to use rims bigger than 15in or can I still use size 15 rims?
Thanks,
these are the links for the parts
https://spoonusa.com/spoon-twin-bloc...p3-gd3-ge8-gk5
^" For use with 280mm sized rotors and OEM-sized brake pads. EG, EK, and '96spec DC2 require Spoon 15" Rotors. Requires DC2 '98spec-sized rotors. Please check wheel and fender clearances before using."
https://spoonusa.com/spoon-15-front-...ra-4h100-114-3
https://spoonusa.com/spoon-sw388-15-...essories-black
Thanks,
He's going to think you're being serious.
No OP, you can't. With something like the Spoon monoblock calipers the largest rotor you could run with a 15" wheel would be something around ~11.5", and even then you'd be very limited to only a few wheels that have proper spoke and barrel clearance (IE DR57 or TE37 or whatever those Kosei wheels are)
egb18c5
Dec 6, 2005 10:46 AM
