1990 Honda accord valve assembly can get to go back after changing the gasket
Old Aug 28, 2023 | 04:47 AM
mariodres1's Avatar
Default 1990 Honda accord valve assembly can get to go back after changing the gasket
I have a 1990 Honda accord. It was leaking oil from the valve cover and the spark plug housing. I changed all the gaskets that needs to be changed but now I can put back valve assembly
Old Aug 28, 2023 | 06:46 AM
hondamark35's Avatar
Default Re: 1990 Honda accord valve assembly can get to go back after changing the gasket
the rocker arm assembly?
did you remove the bolts (don't) or leave them in the assembly?
the end caps tend to shift a little even when you leave the bolts in. try squeezing them inward as you set in on the head. that usually works for me.
MMG
Dec 18, 2017 03:19 PM
1ATony
Jan 28, 2011 08:05 AM
NSL727
Aug 15, 2008 11:47 AM
JeffyHfx
May 18, 2008 10:39 PM
srburk
Jan 27, 2005 12:27 PM
