Need help with wheel fitment on 1994 Honda Civic Ex 2D Coupe
Old Aug 26, 2023 | 01:17 AM
VintageJDM's Avatar
Default Need help with wheel fitment on 1994 Honda Civic Ex 2D Coupe
I found some pretty rare BBS rims on facebook marketplace
RA452 6 1/2 Jx15H2 et 40 4x100 rims
The 4x100 matches my car but i have a question about the hub bore...
The center caps say "56.24.012" which after searching, shows 56mm hub bore size on the wheel.
Does anyone know if these wheels will fit this my civic or if i can use an adapter to? The rims are hard to find for the price im getting them for, professionally refurbished and repainted gold as well.
This guy had these on a 95 miata. Don't know if that is a matching hub bore size or not
Old Aug 26, 2023 | 07:43 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Need help with wheel fitment on 1994 Honda Civic Ex 2D Coupe
Your Civic hub size is 56.10mm, so based on the information that you have given, they should fit. However, since the bore size is only slightly bigger than your hub, you will likely not be able to utilize a hub-centric ring to make it fit your hub, so you will only be able to run the wheels "lug centric".
Old Sep 2, 2023 | 07:24 AM
VintageJDM's Avatar
thanks, I’m cool as long as they fit
Shade93
Honda Civic (2006 - 2015)
18
Jan 4, 2009 12:25 PM
Chuckles99SH
Jun 27, 2007 12:17 PM
bryphotoguy
15
Jul 4, 2006 07:48 PM
hobo79
Jan 26, 2002 06:40 AM
