hondata s300 , ls integra trans ,b20b help tuning
i have a hondata s300v3 on an integra ls ecu, ls trans and b20b. i bought the car blown up in turbo form. ripped everything apart, got a new motor, removed the turbo and want to set an n/a stock or close to stock tune. would i be able to just use the standard basemaps on the hondata new calibrations or what? (i’m new to the honda tuning scene i got a good deal on a setup turbo car and want a fun daily with it) any help will be appreciated🙏🏻🙏🏻
Yea use a B20 base map, just make sure the injectors size and map sensor are the same in the base map as what you're using, if not you can easily change those, and engine should run.
