Starting issue. 92 sedan
Old Aug 21, 2023 | 02:27 PM
Sheetbox's Avatar
Default Starting issue. 92 sedan
Was starting fine till I think I might of over filled it. Cranks but fuel pump not coming on and relay not clicking. Jumping 1 and 7 on the relay connector does turn the fuel pump on but 5 and 7 didnt turn my fuel pump on with the key turned. Is this leading more towards and ignition switch or ecu? And what's some more simple enough test to help narrow it down. I bought a new relay, nothing. No fuses are blown. Someone auto to manual swapped it and the mechanic said they just had a trans wire bypassed and back into itself so someone's handy work. Cel is on but with pins jumped it won't flash. All grounds in the engine bay look eh.
Old Aug 22, 2023 | 02:12 PM
Sheetbox's Avatar
Default Re: Starting issue. 92 sedan
pullingin
Oct 28, 2016 02:56 AM
chandler58
23
Mar 28, 2013 12:22 PM
K1llaturtl3
Dec 24, 2011 11:24 PM
