1991 Honda civic hatch Ecu reading 12 blinks
Old Aug 13, 2023 | 10:52 AM
Fadedhondas's Avatar
Default 1991 Honda civic hatch ecu light blinks 12 times
Hey all, new car owner also new to working on engines. I’m inexperienced but here’s everything going on with my vehicle.
things to know
​​​​​​-200k miles on engine block and body 100k on transmission
- Dual point PGM-FI programmed fuel injection
-automatic
-shifts Nicely (besides first and second)
-had the engine rebuilt
-added cold air intake (original was destroyed)
-changed the plugs oil…ect
-ac stopped working a while ago
-just fixed transmissions solenoid wiring, + o2 sensor wiring
-cleaned map sensor with electrical contact cleaner
-ecu blinks 12 times consecutively.
While driving from 20mph to about 30mph the engine will shake as if it’s missing a motor mount (it’s not) and shift horribly, after I get over that speed it can handle 35-40-50-90mph smoothly with no issues.
I’m trying to figure out what I can do to get rid of the code the ecu is blinking to see if that fixes my cars issues.
this is the diagram I was using but I don’t know if it’s correct for my car
it Says number 1 primary fuel injector but I simply don’t know how to go about this issue where should I start.
I also don’t know the location of the fuel injector they aren’t on a fuel rail like other cars I’ve worked on
Any help would be greatly appreciated thanks!
edit forgot to mention my gas tank lid release’s pressure when I take it off so something may be going on with my evap too
Old Aug 14, 2023 | 05:26 PM
jlicrx's Avatar
Default Re: 1991 Honda civic hatch Ecu reading 12 blinks
Old Aug 14, 2023 | 08:59 PM
jsinher3's Avatar
here’s what the US book for 90/91 civic says. Let me know if you need additional pages.
crxsteve
Aug 10, 2006 10:53 PM
NACvicSi
Sep 3, 2005 09:33 PM
JsNA99si
48
Jun 7, 2004 04:19 PM
exr_pd
Mar 21, 2002 03:37 PM
Ex-ITR5874
Sep 24, 2001 08:05 AM
