08 civic si turbo
Having some problems with my 08 si. Stock k20z3 cx racing turbo kit, 1000cc grams injectors, grams 320 fuel pump, hondata 4bar map. During my etune the tuner noticed a issue with the fueling. After some inspection i realized injectors for cylinder 2 and 4 are not sending fuel. Both positive and negative wires going to injector have power for those 2 injectors. Which i know ground is supposed to get the signal from ecm to send fuel. The other 2 injectors are functioning fine. Ive checked continuity through my harness, continuity in the injectors themselves, checked my fuses and relay, checked my grounds. Anyone else have a issue similar to this. Really appreciate any help!!
