White smoke
Old Aug 10, 2023 | 10:22 PM
thingsnstuff's Avatar
Default White smoke
Hey, I recently purchased a 2000 Honda Civic Hatchback and I’ve noticed that sometimes my car will blow white smoke from the exhaust. Is this something that could be a big problem?
Old Aug 11, 2023 | 07:57 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: White smoke
If it is just condensation smoke, which typically occurs for the first few minutes after cold cranking the engine, and typically ceases once the engine is warmed up... then you have nothing to worry about. If you are also experiencing overheating and/or temperature gauge fluctuations, then the issue may be turning bad.
Old Aug 11, 2023 | 08:03 PM
The engine doesn’t overheat, and smoke comes out only occasionally whether I cold crank it or not. Sometimes it goes all day without it happening and sometimes it will come out almost constantly.
Old Aug 11, 2023 | 08:24 PM
JRCivic1's Avatar
10 Year Member
Community Builder
What brand/type of exhaust do you have on the car ? Sometimes, if the muffler tip is angled up, or there are low spots in the exhaust piping that would accumulate moisture overnight (or collect rain water at the right angle), this water evaporates and appears like white smoke until it is all burned off. If this is your issue, it will NOT smoke when the engine and exhaust system is cold, but once it heats up, the smoking will begin and continue until all water/moisture burns off.
ELSUICIDA
13
Apr 4, 2007 06:07 PM
jdmtim
Nov 20, 2003 01:43 PM
bitr364
Mar 10, 2003 06:53 AM
Malice
Mar 5, 2002 04:07 PM
SIK IN DA HED
Oct 8, 2001 06:46 PM
