1989 crx hf with b18c swap
Old Aug 4, 2023 | 07:50 PM
Clewis's Avatar
Default 1989 crx hf with b18c swap
Hey everyone, I’m new to the Honda world and I bought a crx with jdm b18c swap not running with a blown clutch. It had some shoty kill switch wiring and an alarm that I have since removed. I have only got it running and driving recently and it has a hesitation issue around 4-5k rpm’s wot and 1/4 throttle. I have replaced the fuel filter, tps, map sensor, iacv, and the fuel pressure regulator and nothing has changed. The car also ran and drove great before I bought it. I can’t find any vacuum leaks. Ignition timing is set at 16 degrees top dead center. I have also checked mechanical timing since I have replaced the timing belt and everything checks out. I’m not sure how to or what to troubleshoot from here, with that said any help would be greatly appreciated thank you.
Old Aug 5, 2023 | 02:18 AM
fin781's Avatar
Default Re: 1989 crx hf with b18c swap
No codes I'm assuming? What computer are you running.
Old Aug 5, 2023 | 07:49 AM
Clewis's Avatar
Correct no codes and it has a p73 ecu
Old Aug 12, 2023 | 09:33 PM
eos_eos_eos's Avatar
Maybe the spark plugs, wrong gap or worn out.
Old Aug 15, 2023 | 06:23 PM
Clewis's Avatar
I have also replaced spark plugs and I have them gapped at 0.44
Leftlaneb
Jan 13, 2017 07:03 PM
nieldcrx
Jun 3, 2009 07:06 AM
ddenson
Jul 23, 2007 06:55 PM
