Help with idle
Old Aug 2, 2023 | 11:41 AM
josejosejose's Avatar
Default Help with idle
My car d16y5 swap has been idle bouncing. when the car is cold temp it operates as normal but when it warms up and i give it gas the idle likes to stick at 1.5k - 2k (normal is ~750rpm) until i pick up under the gas pedal with my foot and pull up the idle drops to ~250 rpms almost dying anyone have an idea of what it is, had ce light for water temp sensor i replaced it only ce light for o2 but its been that way for months please any help appreciated
Old Aug 2, 2023 | 06:30 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Help with idle
Have you checked and cleaned the throttle cable spring on throttle body?
If your cable it tight and the throttle plate is sticky with gunk, it may not be returning to home position causing a high idle until you force it with pulling the gas pedal up.
Old Aug 3, 2023 | 06:03 AM
thategcivic2008's Avatar
Check your throttle components and look at your intake manifold. I had a idle problem when one of the hoses got old
Thorgs
Apr 20, 2008 09:31 AM
97hb
Jan 24, 2003 11:12 AM
