Bad Clutch?
Not the clutch plate. Can you drive it? You should be able to shift gears even if you have not pushed the clutch pedal while driving by playing with the gas and shifting. You bled the line fully? Like a cup of oil through it? How far does the fork move when you push on the clutch? Take off the slave and move the fork around. Does it feel like its on the fulcrum ball? What symptoms leading up to this?
