Accidentaly touch starter pos with clutch hose metal for a milisec (ground).
Old Jul 25, 2023 | 11:34 AM
Ekcivic329#'s Avatar
Default Accidentaly touch starter pos with clutch hose metal for a milisec (ground).
Hi guys
i was replacing my clutch pump hose and i accidentaly touched the starter pos with my clutch pump hose(metal) for a milisec(twice) & caused a little spark and i immediately remove the negative pos terminal on battery.
Car starts fine nothing weird .
Checked all fuse(unde hood & under dash) all good. Checked battery, ground & alternator . Everything is working well …
fuel pump relay, lamp, interior accesory, radio everything is working fine . Nothing’s wrong.
I even remove my ecu casing and see if anything is burnt but everything seems fine .
So should i be worrying for anything ?
Old Jul 25, 2023 | 01:22 PM
Relic1's Avatar
Default Re: Accidentaly touch starter pos with clutch hose metal for a milisec (ground).
there is always a weakest link, sometimes that link is the connection to the ground that you just made.
It sounds like you got lucky and only scared the crap out of yourself.
The fuse you would have blown would have prevented cranking.
Old Jul 25, 2023 | 08:41 PM
I’ve seen alot of post saying pos wire touched ground and pcm or some sort of fuse broke
My clutch pump hose the metal part where we tigthen down the pressure screw touched the starter pos cable I think it contacted part of the starter .
So the main concern here is should i be double checking or worry about anything ?
RecklessEJ
Jul 13, 2011 12:05 PM
B16COUPE94@AIM.COM
Feb 18, 2008 05:43 PM
EK k kay
Jun 19, 2006 10:25 PM
Spectrum24x
May 24, 2006 01:53 PM
