H22a Type S ATTS. What axle to use?
as the title says. I bought a 5th gen accord with a Type S H22a paired with an M2U4 Manual Trans ATTS recently. I didn't search thoroughly before buying this car and all I know was the difference b/n this Type S and the other H22 are on the engine. I didn't know about this ATTS system.
When I bought the car, it had already a CV joint or axle problem and I thought it was only a simple axle replace. I've yet to replace my axle since upon researching this forum, a stock axle from accord won't fit on my engine and trans If I got that correct.
Solutions so far from this forum is to change to base transmission but that needs fabricating parts to eliminate the ATTS.
I've also read that you can have your axle custom made so it fits but there's no one in my area that capable of doing it.
Is there any other way to work with this other than selling the whole swap/car to a base H22?
Thanks a lot!
Thanks a lot!
have you checked your vin/chassis number on partsouq.com? that should give you the part numbers you need, they may even have the parts you need too. Also check amayama for the parts etc
What are you based?
What are you based?
I'm from South East Asia and ordering a heavy car parts internationally is out of my budget. I think even with my chassis number, they'll still give me the exact ones for the stock accord since it's the chassis not the transmission where the axle mounts.
I'll probably just sell it and hope for any buyer, Thanks!
MugenAccordSedan
May 27, 2004 11:41 PM
