Honda Accord 2018- Current This is the place to discuss all things Honda Accord related for the 2018- Current model year
2023 Accord 174 miles pulling left under braking
Old Jul 14, 2023 | 07:08 AM
crobar2k's Avatar
Default 2023 Accord 174 miles pulling left under braking
I have a new 2023 Accord Hybrid Touring with 170 miles. The car that has a slight but noticeable pull to the left under braking and regen braking. I noticed it soon after picking up the car. I took it back to the dealer and they checked the alignment, made some adjustments but the problems remains.
I took the service manager for a ride and he agreed the pull was still there. He told me to drive it to 700 miles and come back in if the problem doesn't go away. He said new brakes can take time to adjust.
Is this a thing? Do brakes really need time to break in or am i getting the run around?
TIA.
Old Aug 3, 2023 | 04:55 AM
waydennis's Avatar
Default Re: 2023 Accord 174 miles pulling left under braking
There is a break in period for brakes, but in my 42 years of driving I have never experienced a pull with new brakes even if I did the brake job.
You can expedite the process by bedding in the brakes. Brake Bedding Process
If they continue to pull after bedding, I would take back to dealer and start a lemon law return as I suspect a mechanical issue is the real issue.
Old Aug 3, 2023 | 07:28 AM
crobar2k's Avatar
What mechanical issues could there be?
Old Aug 3, 2023 | 08:41 AM
waydennis's Avatar
I have owned a Honda for 3 days, so I don't have product specific knowledge. But a malfunctioning brake piston could be sticking and binding on the rotor. It grabbing harder than the others could pull your car to that side.
If the alignment is OK, That's the next thing I would have checked.
Old Nov 1, 2023 | 05:51 AM
roddrick's Avatar
Premium Member
5 Year Member
Any update on this matter? I have a 2023 accord hybird sport L and i work for a honda dealership. I haven't heard of anyone having this issue your having.
Old Nov 1, 2023 | 11:13 AM
roddrick's Avatar
Premium Member
5 Year Member
also with a pull could be a bad tire. I have seen old and new tires cause this issue.
Old Nov 3, 2023 | 02:12 AM
Bgchuletta's Avatar
You're getting a run around for sure. No car, with good operating brakes, should pull to the side when braking. Sounds like the left brake system is applying more pressure than the right side. I would definitely bleed the brakes and see if that fixes your problem. Air in brake system can definitely cause this issue.
Old Nov 10, 2023 | 06:20 AM
feels's Avatar
1. Fill in the tire air pressure - ensures all 4 tire have the same pressure
2. Inspect tie rod - damage?
3. Push out brake piston for the front - inspect rust. Maybe rust build up with where car is parked, and get salt into it
Cfc09champs
Mar 8, 2020 01:31 PM
Pauls94accord
Jun 12, 2018 10:58 AM
Chimi
Jun 10, 2013 02:52 PM
jkoshy18
Jun 4, 2004 03:23 PM
KCHybrid
Nov 19, 2002 05:12 PM
