I’m looking for the part number or the name of part number 16. My shift linkage keeps falling off because I don’t have this to hold it. Thank you appreciated
No your giving the wrong part I need I need the part where it connects to the tranny not the shifter side your giving the wrong part and the website is for a crx
What you need is part number 54304-SK7-000. List price is $6.57. Make sure you use a short 8mm bolt so you don't knock a hole in the inside of the transmission case and allow fluid to leak out. The factory length is only 18mm under the flange head.
