Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
New (remanufactured) transmission won't go into reverse
Old Jul 3, 2023 | 04:30 PM
AY15's Avatar
Default New (remanufactured) transmission won't go into reverse
I just installed a remanufactured transmission in my 2002 Honda Civic 1.7L automatic. The install went well but when I started it, I can only get it to go into Park or drive. It will stay put in park, reverse and neutral. It will roll forward in drive. It's in my barn so I can't tell how far forward it'll go or how it runs going forward.
The reverse lights do turn on when I put the car in reverse. I did notice that the gear indicator on the dash didn't light up perfectly, sometimes not lighting up when it's in neutral or reverse. Any ideas?
Old Jul 3, 2023 | 05:49 PM
DCM1's Avatar
Default Re: New (remanufactured) transmission won't go into reverse
Is the range switch adjusted properly?
Old Jul 3, 2023 | 06:04 PM
AY15's Avatar
I will make sure to check this. Wouldn't it not start if it was in the wrong position?
Old Jul 5, 2023 | 10:44 AM
AY15's Avatar
I checked that and everything is lined up the way it should be.
Old Jul 5, 2023 | 03:31 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Check the connector, terminals, and wiring at Connector C106.
Old Jul 5, 2023 | 06:12 PM
AY15's Avatar
Anything in particular I should be checking for?
Old Jul 5, 2023 | 06:17 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Check that the terminals are not bent, clean, etc.
Check that wires are not pinched or broken.
Check the connector is tight.
Old Jul 6, 2023 | 05:32 PM
AY15's Avatar
​​​​​​Connector looks good. It was one of the harder ones for me to get unlatched, and it was tough this time too. It looked clean and nothing pinched.
The other connector pointed out in that photo was also really hard to disconnect and some of the plastic on the outside did break. Everything still connects well though.
Old Jul 6, 2023 | 06:13 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Check ground bolt G101. Make sure that was bolted down properly.
Old Jul 7, 2023 | 08:14 AM
AY15's Avatar
I actually never even unhooked that ground, so it still looks good. One thing I know is that there's nothing I can do to fit a crush washer above and below the mount for the bolt I'm pointing to in the photo. It's a very slight leak, but I'm wondering if that could be something causing an issue. I have been checking my fluid level and I still have plenty. I just don't know the name of the bolt and I think maybe it's stripped at some point in the threads.
Old Jul 7, 2023 | 09:02 AM
AY15's Avatar
The car isn't going into drive consistently now either. I can feel/hear a difference from park to reverse/neutral, and then again when I switch to drive. Very lost at the moment.
Old Jul 7, 2023 | 10:33 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
That is not ground G101. G101 is not on the transmission. The G101 ground is the main ground for the PCM; the transmission controls goes through the PCM.
Old Jul 7, 2023 | 10:55 AM
AY15's Avatar
Sorry, I didn't mean I thought that was the ground. The G101 ground was still in tact the whole time and looks good.
I was pointing out what I think is called a banjo bolt (but confident in that) that I can't get to thread with the crush washer above and below the mount. I am curious if that could be my issue because there is a slow leak due to that.
ChevelleSSLS6
Jul 5, 2023 02:27 PM
2002_accord
Aug 23, 2016 02:31 PM
krisfnbs
21
Feb 9, 2015 12:29 PM
Pbanto
Transmission & Drivetrain
May 20, 2009 12:06 PM
JSpekBB4
Feb 21, 2007 06:53 PM
