Ek civic swapped gsr b18c
Old Jun 23, 2023 | 10:43 PM
R3lkstar's Avatar
Default Ek civic swapped gsr b18c
So I’m having starting troubles. Every time I turn the ignition is a click no crank but I go on and try a couple times and then it cranks.Then I found a eroded ground that’s from the transmission. Can that be the problem ?
Old Jun 24, 2023 | 07:08 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Ek civic swapped gsr b18c
It sure can.
Old Jun 26, 2023 | 12:55 AM
MorningStar★'s Avatar
it would be a good idea to clean and secure the eroded ground connection you found. If the problem persists, you might want to have the battery, starter, and ignition switch all checked out.
scoobntaz1996
16
Jun 19, 2018 05:08 PM
michael116
Oct 31, 2011 11:20 PM
Ekb18c5_BR
13
Sep 6, 2007 04:51 PM
jdm styles
Jan 15, 2007 02:44 PM
