Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2003 civic won’t shift past 4k rpm’s!
Old Jun 20, 2023 | 08:17 AM
adamg1717's Avatar
Default 2003 civic won’t shift past 4k rpm’s!
Hi guys i need help with my civic, I recently had the head gasket repaired, I notice that when going on the highway at high speeds or up hill when rpm’s hit 4k the engine will stall/shake until i let off on the gas it will shift( sometimes). I was looking at other forums and it said it could be a clogged fuel filter, bad fuel pump, or my transmission speed sensor could be going out or the transmission is bad.
Old Jan 29, 2024 | 01:58 PM
benchwarmer's Avatar
5 Year Member
Default Re: 2003 civic won’t shift past 4k rpm’s!
I would think timing is good , Could be a crank/cam sensor loose , misaligned or damaged crank/cam journal even if just a little disrupting sensor at higher RPMs . Intake leaks ? ?
Old Jan 31, 2024 | 04:50 AM
5 Year Member
Those can be a common problem and need replacing . Frequent oil changes help to prevent their demise
Old Feb 1, 2024 | 04:15 AM
5 Year Member
I was watching a video where the journal the sensor picks a signal from was bent and at high rpms the signal would get lost . You may need a real time diagnostic scan , but also a good technician to figure out a puzzle like this .
april_q08
Oct 21, 2013 07:26 PM
Revolver123
73
Sep 14, 2008 03:57 PM
needaimport
Feb 3, 2005 08:28 PM
brenerb
May 22, 2003 10:17 PM
