Head bolt torque
Old Jun 18, 2023 | 07:26 AM
Apollo11's Avatar
Default Head bolt torque
2000 Accord LX F23A1 manual 360k
I have a question that I was surprised to not find threads on already. I've run into 2 different methods for tightening/ torquing head bolts. On YT I've found several videos that mention a 3 step torque procedure, 3 different torque values stepping up. (The head bolts aren't TTY on this year and model apparently). The other method is what's shown in the service manual, which is torque to a specified value, then making a tick mark at 12 o'clock on the bolt head, and tick marks around the bolt head at 3, 6, and 9 o'clock. Then turning the bolt until the bolt mark lines up with 6 o'clock (180 degrees) for used bolts or to 9 o'clock (270 degrees) for new bolts.
I assume there's logic behind both methods, I just don't know what it is, maybe one method fell out of favor for the other?
So you guys who've done this job, which method do you use?
crxguy406
Mar 16, 2013 09:04 AM
xDicktonesx
May 1, 2007 11:35 AM
StraightCivic
Feb 12, 2006 11:49 AM
jmcclell
Aug 19, 2004 01:25 AM
See Are X
Feb 6, 2003 12:31 AM
