1996 Accord is totally dead electrically
Dear Experts,
I have a
1996 Honda Accord EX
2.2 VTEC engine
278K miles
Recently, I worked on changing the rear disc brakes
Calipers, bracket, pads/shoes.
Yesterday, I had someone help me bleed the brakes
Then when I went to start the car, there were
no lights, and no sounds, like there normally would be.
Charged the battery.
Light on charger, indicates that it's fully charged.
Cleaned the connections to the battery.
But, when I turn the ignition key, nothing!
This video:
Top 5 Problems Honda Accord Sedan 6th Generation 1998-2002
1A Auto: Repair Tips & Secrets Only Mechanics Know
Sep 29, 2020
Mentions
6: Frayed Negative Battery Wires
Has anyone had experience with the negative wires?
Does this sound like the culprit?
Any other ideas?
Thanks a lot
I have a
2.2 VTEC engine
278K miles
This video:
Sep 29, 2020
Mentions
Any other ideas?
Thanks a lot
Just because you charged the battery does not mean it's any good. If it's old and degraded a full charge could be very little. Load test it.
Did you check the main battery fuse?
Im going to guess grounding personally. Check the battery to frame ground, then the engine to frame ground etc.
@nicolaselias
Thanks Nick for the useful suggestions.
I watched this today:
Honda Accord Complete Battery Cable Replacement
PeanutButterMan
Jul 1, 2021
PeanutButterMan
Jul 1, 2021
And ordered some cables from Autozone
For the Negative terminal
GP Sorensen Battery Cable AA22-4TB
Part # AA22-4TB
SKU # 1053007
https://www.autozone.com/batteries-s...tb/1053007_0_0
$29
Part # AA22-4TB
SKU # 1053007
$29
For the Positive terminal
GP Sorensen Battery Cable DA33-2UT
Part # DA33-2UT
SKU # 1053022
https://www.autozone.com/batteries-s...ut/1053022_0_0
$42
Part # DA33-2UT
SKU # 1053022
$42
It's fixed. Here's what I did.
Changed the battery cables, both positive and negative.
Cleaned all connections with rubbing alcohol.
See the corroded negative cable.
Corroded negative battery cable
One hard part was getting the cables fit into the Honda specific hardware that
holds them in place, between the battery, and the connection at the other end.
And, the positive lead to the fuse box was too big.
I had to trim it down to size.
And make a little slot with my Dremel, so that it fit into the plastic fuse box.
But, still no dash lights, head lights, or start.
Dead as a door nail.
Battery voltage was good.
Pulled the 50 and 100 amp fuses (Phillips screwdriver required)
Tested fuses with the electric multi meter.
Current passed through the fuses
Cleaned contacts/connections with rubbing alcohol, and reinstalled the fuses
Cleaned and reattached the battery cables.
Headlights worked
Dash lights worked
Car started
Yeah!
So, after 27 years, some electrical connections got dirty.
Headlights worked
Dash lights worked
Car started
Yeah!
Jones2011
Aug 19, 2019 07:20 PM
prashu123
Jan 20, 2011 11:16 AM
MHonda06
May 16, 2008 07:04 AM
