Will crank but won’t turn over
Old Jun 11, 2023 | 05:37 PM
Civic850's Avatar
5 Year Member
Default Will crank but won’t turn over
So I had my 91 civic dx hatch running a few years back and trying to get it up again and on the road I’ve put a new battery with new ground cable but I’m not get any dash lights on and I don’t hear the fuel pump primed or the relay click my friend gave me a relay from his civic to try and same scenario if I crank it while spraying starter fluid it acts like it wants to turn over my next thought is the ignition switch im not sure what’s going on it’s got new fuses and I would hate to spend the money and not fix the problem I was wondering if anyone had any ideas or advice
Old Jun 13, 2023 | 01:30 PM
Efmaniac's Avatar
Default Re: Will crank but won’t turn over
Check ground wire on driver side between chassis and valve cover
Old Jun 13, 2023 | 02:23 PM
jlicrx's Avatar
any codes showing on the ECU? always the first thing to check
Old Jun 13, 2023 | 05:03 PM
Civic850's Avatar
5 Year Member
Originally Posted by jlicrx;[url=tel:52727982
52727982[/url]]any codes showing on the ECU? always the first thing to check
what codes would you be referring to ?? It’s OBD0 so there is no way to show codes on a scanner and there are no lights on the dash to show any codes
Old Jun 14, 2023 | 05:29 AM
jlicrx's Avatar
pull back the carpet on the passenger side to expose the top of the ECU - turn ignition to "on" - look at the red LED on top of the ECU - count the number of flashes on the LED - if there is more than one code stored, the LED will flash for the 1st code, pause, flash for the next code, pause, etc.
File Type: pdf
lee303
18
Oct 19, 2022 09:32 PM
WhiskeyHammer
May 18, 2021 03:05 PM
Stephen122193
Jan 3, 2016 07:19 AM
TheWhiteEF
May 9, 2013 06:08 AM
transitions
Jan 9, 2006 10:36 AM
