1993 Cluster Question
Old Jun 10, 2023 | 11:29 AM
Zmelli's Avatar
5 Year Member
Default 1993 Cluster Question
Can you run a 1993 EX Cluster in a 1993 Accord LX? LX does not have ABS, will the ABS circuitry in the cluster simply stay off and not activate the ABS Light? Thanks.
Old Jun 11, 2023 | 08:30 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1993 Cluster Question
AFAIK the only two differences for a given cluster is if one is MT and the other is AT. MT cluster will not have the gear selction lamps.
Look at the back of both clusters, verify the required lamps are filled in for your vehicles needs. Just mimic what your original cluster had.
Old Jun 12, 2023 | 03:07 PM
Zmelli's Avatar
5 Year Member
Update. I went ahead and installed the Cluster, The ABS light does not come on, everything works. I will need to check the backlight and dimmer when it gets dark. This is my third time replacing a Cluster and it's a bear, the screw behind the lighter is hard to change with the lighter installed. I should have looked up how to remove the lighter.
utturkey
May 25, 2011 05:42 PM
honda.lioness
Apr 17, 2009 02:20 PM
ekb16a
May 5, 2007 05:23 PM
LaEzEnT
Feb 23, 2006 09:56 PM
