correct way to wire ecu fan control (a12) for cars that dont have a ecu fan control
hello everyone
whats the correct way to wire ecu fan control (a12) for cars that dont have a ecu fan control (most eu models) ?
i used to just run a wire from ecu pin a12 tapped to the green wire of the fan switch. and adjust fan control from software. it worked fine but im not sure of thats the correct way to wire, it, some sources says another relay is required,
thanks
thanks
hello everyone
thanks
thanks
so what you describe is exactly how the OEM wiring works.
see attached diagram from the manual.
Fans page from the ETM for the 92-95 civic.
ale5six1
17
Apr 29, 2013 01:32 PM
AgentJam
Mar 17, 2004 05:23 PM
Project_ED8
Dec 8, 2003 09:32 PM
