B series Pro Charger supercharger kit complete (High boost) Low miles!! Look!!
Up for sale rare B series Pro Charger high boost kit. These are rare and expensive! costs $6K brand new. It comes with lots of new stuff and upgraded parts. Piping and intercooler will fit 94-01 Integra with stock GSR manifold or Skunk2 Ultra manifold. Will fit other chassis with B series engine. 100% complete plug and play. Will make 365 HP easy on the right setup and fuel. A.C and P.S compatible! self-contained oil system and Intercooled kit.
Reason for selling is I was able to upgrade to a C-2 blower from Pro Charger which is not much different than the C-1 blower I'm selling, so I purchased a Brand-new C-2 kit which was built for my application, and I already received my kit so now I'm ready to sell my C-1 kit.
This C1-A Pro charger blower was purchased brand new from pro charger has approx. 9k miles (only 3 oil changes!) has lots of life left. No shaft play no issues 100% guaranteed. I sold my last kit and purchased this one brand new from Pro Charger, kind of like what I'm doing now except I have a C-2 blower/ kit this time so that's why I'm selling my C-1 blower/kit.
These are carb legal in 5o states including CA! Carb approved paperwork/ info and carb tag available for 94-01 Integra GSR 1.8L/ Civic SI 1.6L.
Here is the carb website info below that I will have printed out for you with a brand-new carb tag! (Please note the kit is 100% carb/street legal up to 12 psi BUT in order to pass smog physically you will need the Pro charger FMU or a universal FMU to control the fuel with the stock ECU to pass emissions
90* elbow welded to compressor housing with used K&N filter, The rubber 90* elbo with filter comes off pretty easy from vibrations so that's why I had a aluminum 90* elbo welded so it wouldn't fall off anymore!
New support bracket
New hardware
New custom made 2.8' pulley (12-14+psi) by Smooth flow Pulleys I can order any size boost pulley you want for $60 extra.
New upgraded idler pulley by Smooth flow Pulleys
Modified main bracket for tighter belt wrap with idler pulley used Gates belt looks brand new, also will include a brand new Dayco belt that should fit fine.
brand new Red Tial BOV for SC application from go auto works with vacuum line
Brand new charge pipe clamps
Brand new upper charge pipe (2.75') fits stock GSR manifold or use the extension to fit a Skunk2 ultra street manifold, should work with other manifolds with a little work. Has the vacuum port plugged in case you want to use the upper charger pipe as a cold air intake, all you need to do is remove the allen tap and install a filter.
2.5’’ Intercooler
All couplers included
1 box of new pro charger oil bottles
Everything is clean and looks brand new! Just needs a new engine to slap on too and Install is about 25-30 min! Might be missing stuff but P.M me if serious with any? no low baller no trades. The only reason I'm selling is I'm building another Pro Charger setup using a C-2 series blower/kit that I already received from Pro Charger
Price drop $4,000 firm!
I will have everything boxed in the original pro charger box just like it comes brand new as well as have everything labeled and packaged. Intercooler kit is boxed separately so it will be 2 boxes maybe 3 if the filter doesn’t fit in one of the boxes.
Prefer local pick up but Shipping will be available for an additional charge.
I have 100% positive feedback check my vouch thread below and buy with confidence,
