Best wheel spec for best fitment
Old Jun 5, 2023 | 03:39 PM
99-EK's Avatar
Default Best wheel spec for best fitment
So I'm looking at getting a new set of wheels but not sure what specs I should run. Right now I'm running 15x7.5 with +15 offset on 195/45/15 toyo's. They poke out a bit and I'm not able to tuck them without camber. I'm wanting to stay in 15in range for what I'm doing. I run the dragon from time to time, and like to do touge. I just want a nice clean and flush fitment and hoping to hear and see what other people are running so I can get an idea of what to run
Old Jun 5, 2023 | 05:02 PM
Chance EG's Avatar
Default Re: Best wheel spec for best fitment
195/45/15 is already an unusually small tire to run on these cars. 15x7.5 isn't an extremely wide wheel either, but you could down size to a 15x6 or 15x6.5 and run 205/50/15 tires.
Your 195/45/15 against the 245/40/15 I have up front in my car would be a funny comparison.
Old Jun 5, 2023 | 06:02 PM
99-EK's Avatar
Your 195/45/15 against the 245/40/15 I have up front in my car would be a funny comparison.[/QUOTE]
the reason for the weird setup was when I first got my ek a year ago, previous owner had 17s on it. so i took my wheels off my teggy and switched them. Originally i was running 55s but they rubbed really bad and i couldn't go as low as I wanted to. I'm not looking for like slammed on the ground but a good track setup. I plan to run 205 later down the line but I'm stuck on what wheels I want and the specs with offset. I know I want 15×7 or 15×7.5 but not sure on offset
Old Jun 5, 2023 | 06:29 PM
Chance EG's Avatar
On our cars, for 15's, generally somewhere between +25 and +35 offset is ideal.
Old Jun 8, 2023 | 03:02 PM
AsEMaster's Avatar
Premium Member
Loved
Community Favorite
My '95 EJ has the seven spoke OEM 14" alloys with 195/60s on them. I have been thinking about going to 15s so I can shelve the OEM wheels, and maybe pull a little more laterally along with the fresh suspension just put under it.
Knowing the tire sizes and wheel specs we can getaway with stock-ish setups, really helps. Thanks.
My coupe has new adjustables. and I dropped the rears 1.25" and the fronts .75". It is taking a little getting used to but damn it's fun.
The ride is like that of a little slot car, it does not slide, it turns.,, I am probably going to upgrade the brakes next. >;^D
Old Jun 9, 2023 | 07:21 AM
Sic_DA_Nine's Avatar
perfect spec for me would be 15x7 +27 on a 205/50
The Destroyer
28
Mar 16, 2011 03:41 PM
2000EJ8
Nov 12, 2010 08:09 PM
ef8-dc2619
Nov 5, 2009 08:34 PM
jdmland
Sep 20, 2008 12:39 PM
Racer
Sep 24, 2001 08:48 PM
