Bad radiator cap(s) cause of coolant leak?
Old May 31, 2023 | 09:24 AM
J2000Civic's Avatar
Default Bad radiator cap(s) cause of coolant leak?
I've been having a slow coolant leak that seems to show up after about every 150 miles. By that point the temperature begins to rise above normal. After I pull over and cool off enough to check, the cause is always the same: about a quart low on coolant. I've located where there seems to be coolant pooling on top of the fan shroud (picture 1). But I'm having trouble finding exactly where the leaks is.
So far I've replaced the rad cap with two different kinds (pictured) and the leak continues. Yesterday I replaced the hose and clamps to the overflow tank. Though the rate at which I'm losing coolant seems like it's slowed, I still noticed a pooling on top of the fan shroud when I popped the hood after driving yesterday. Is there something I missing that I should check? Are these radiator caps garbage, and if so which kind would you suggest?
I'd appreciate any help. Thanks,
Pooling of coolant
Old May 31, 2023 | 07:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Bad radiator cap(s) cause of coolant leak?
Do you know what brand radiator is in the car ?
Old Jun 1, 2023 | 06:30 AM
J2000Civic's Avatar
No, unfortunately. Tried to see if I could locate something on it. What I found that I'd hopped might be a product number on it, turned out to be the kind of plastic used in the top portion. (PA66-GF30).
Old Jun 1, 2023 | 08:21 PM
JRCivic1's Avatar
10 Year Member
Community Builder
The chalk all over everything suggests that fluid is spraying out heavily... I suggest you get a helper, crank the car, rev the engine to about 2000 RPM and hold until the cooling fan comes on a couple-three times while you watch the radiator... or until you SEE where the fluid is spraying out from.
Old Jun 2, 2023 | 08:50 AM
Maxcapacity's Avatar
Try putting a zip tie on the or small clamp on that over flow hose coming off the neck of the rad.. Not sure how tight fitting that hose is on there but it could be leaking from there.. only I am a bit doubtful on that causing your issue. Looking very closely, it looks almost like there are hair line cracks in the plastic on the main plastic top body near the neck.. Could just spend $70 and get a nice aluminum rad off ebay (recommend AJP Distributors, excellent quality) and call it a day.
tony_sol22
Jul 19, 2021 08:10 PM
02CRV_0
Honda CR-V & Element
29
Sep 24, 2019 08:03 PM
91civicsikid
13
Jun 24, 2014 03:23 PM
thechineseone
Nov 28, 2008 11:26 AM
DJester187
Jul 3, 2006 08:31 PM
