Hello everyone, I went to the market for an engine I needed, what I found there was an engine with VTEC, the head code is P2M-2, and Block code VA-AN. I have no idea what engine it is, the D15, or D16?
Help needed!
In the last pic you posted the valve cover is marked "F-22" in chalk. I would assume its an F-22 engine.
Lol no, it's just chalk it's common here to just write anything here.
I need details on the Honda Block Code: VA-AN, Head Code: P2M-2.
That's what's written on the engine. Cannot seem to find this info on this anywhere.
I've heard that a lot of (if not all, I really have no clue) blocks in Malaysia and the Philippines have no block codes similar to what we see on the US or Japanese blocks, but have codes like VA-AF and VA-AN. Unfortunately I have no clue where you can find out what these codes correspond to though, there doesn't seem to be much info out there.
Really.... Why does my JDM D swap say D16A on the block...
Post a picture of the block stamping. Where exactly does it say "VA-AN" ???
You are right, there's little to no info available on these Block Codes (VA-AF, VA-AN) and it somewhat leads to Philippines, thai etc. The question is now how do we know what the heck do these codes represent, what kind of D series? Maybe we could get some help with the Head, it's a "P2M-2", a lil help on this too
And if someone's from the Philippines, Malaysia, Thailand, pls help us identify the block, thanks!
According to my buddy Mike Kanzai @kanzaiperformance in the Philippine's and what AydenA20 said, these engines with VA-AN - VA-AF are from Taiwan DM and similar to d16y engine from Civics Eg Ek Es
Hope this helps.
I recently purchased a surplus cylinder head with white markings on top that says VA-AN. I can guarantee you that there are no VA-AN blocks/engine locally made in the Philippines. A mechanic mentioned that VA-AN is from Malaysia (don't quote me on this). The cylinder head I got was a P2J 20 camlobes, the local Philippines PH16A (similar to a D16Y5) only has 16 camlobes.
My Mechanic also had a VA AN engine, he said it was similar to D16Z6.
