A/C belt Squeal
Old May 28, 2023 | 10:40 AM
WHlTEHE4D's Avatar
Default A/C belt Squeal
Ok, so i have a 1995 del sol si with the d16z6. I recently did the headgasket, timing belt, clutch and flywheel, and input shaft bearing. All of that went fine, but the on issue im having is the A/C belt squeals like crazy. When i first tightened it to be tight but not too tight (right about where my non-squealing p/s and alternator belt are) it squealed at all rpms, weather the ac was on or not. I then loosened it, and it would stop squealing, until i turned the ac on and it would slip and squeal. So I tightened it some more, and no more how precisely i tighten it, its either “too tight” and squeals all the time, or too loose and slips on the compressor. I also went and got a new belt and cleaned all the pulleys to try and remedy this and the symptoms are the exact same. I do not know what could even cause this, and i dont know why it would only start doing this after i take the belt off and put it back on. Has anyone had this issue or know what it might be?
Old May 28, 2023 | 02:45 PM
WHlTEHE4D's Avatar
Default Re: A/C belt Squeal
So i figured it out, i had the idler pulley on backwards :p. Sometimes im just a lil silly like that
Old May 29, 2023 | 03:38 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Backwards - as in the idler pulley was flipped?
I did not know you could do that.
Old May 29, 2023 | 08:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Apparently you can !!! Congrats OP on finding the issue... and thank you for posting your solution so future "lookers" can read this.
Old May 31, 2023 | 03:02 AM
wunfstgsr's Avatar
Loved
Community Favorite
I was going to say spray some belt dressing that stuff is tacky as a ****! glad its figured out!
seulja
Jun 24, 2015 06:06 AM
nick105
Honda Civic (2001 - 2005)
Jul 31, 2013 10:18 PM
typecastaaron3
May 22, 2008 08:56 PM
oxSLEEPERxo
Mar 20, 2005 11:23 AM
Atiyeh
May 30, 2002 03:34 PM
