Rust and repairing brake lines
Old May 25, 2023 | 10:06 PM
JCTyler's Avatar
Default Rust and repairing brake lines
I'm working on replacing my trailing arm bushings and discovered a brake fluid leak from a crack in the metal brake line behind the rear drum. The main problem is rust from canadian winters. I want to replace the brake line but everything is badly rusted.
To complicate things further the bleeder valve won't open, and the two wheel cylinder mounting bolts are stuck because of rust. I want to stop the leak and replace the rusted section of line. I've used a heat induction gun and penetrating fluid on the bolts but didn't have any success with doing that. It was hard to focus the heat on the right area because it's tight.
How can I remove the brake cylinder with rusted mounting bolts?
How about disconnecting the hard brake line from where it connects you the rubber brake hose?
Any tips?
1999 Civic Canadian spec Si
Old May 26, 2023 | 05:29 PM
JCTyler's Avatar
Default Re: Rust and repairing brake lines
I got this far today and cut off the right wheel cylinder
So now I'll replace the rear passenger side wheel brake cylinder and brake line. My question is whether I can get away will only bleeding the system from this one bleeder?I'm pretty sure I won't be able to open the opposite rear brake bleader due to corrosion. What do you guys think?
Old May 27, 2023 | 04:27 AM
youstolemybeer's Avatar
5 Year Member
gonna have to bleed both sides, sorry. Sometimes a grinder or cutting torch is your only option.
Good luck
Old Jun 2, 2023 | 05:53 PM
JCTyler's Avatar
I bled both sides and replaced the right line. and replaced the fluid. Repair was a success.
Old Jun 3, 2023 | 07:49 PM
oneheadlight's Avatar
Was lurking, reading your story.. glad to hear you got both sides repaired and bled! awesome!
Floren
Honda Civic (2006 - 2015)
Jun 25, 2018 07:18 PM
crazyguy
Apr 20, 2008 09:58 PM
PINKS
Oct 18, 2007 04:25 PM
arielmalespin
Mar 28, 2007 03:48 PM
B18C Turbo
Aug 30, 2006 12:46 PM
