Valve Cover Bolt Thread, R18
Hello,
I have stripped a thread in the head for one of the valve cover bolts while finishing up a valve adjustment. Anyone know which thread it is? I didn't have tools to measure it. It might have looked like M6x1.
I'm planning on threading an insert if I have to remove the cover again in the future.
Thanks!
Thanks!
Can you tell me how you're about to do it? I stripped it years ago and haven't done anything to it yet Mine was stripped in the rear, where there's little room to work with.
The thread pitch on a M6 bolt likely is 1.0.
See my post #5 in this other thread which has some info. regarding thread diameter and pitch.
https://honda-tech.com/forums/tech-m.../#post52421538
Here are the torques for the cowl cover:
6mm bolts (5 bolts total): 7.2 lbf x ft
8mm bolts (4 bolts total): 16 lbf x ft
