1992 Honda Civic LX / Ballade luxline 1.5 NO Spark issue, carburetor conversion.
Old May 23, 2023 | 08:27 AM
Edward94's Avatar
Default 1992 Honda Civic LX / Ballade luxline 1.5 NO Spark issue, carburetor conversion.
Hi.
I have a 1992 Honda Civic LX 1.5, also known as a ballade Luxline 1.5 in South Africa ( same motor though)
I have a no spark issue.
The previous owner converted the car from fuel injected to carburetor, no idea why he did that but I have no spark.
I have replaced the Ignition Module and the Coil, cap and rotor is still good and plugs and wires.
This is the large distributor with the ignition module going over the distributor shaft.
The ecu and main relay is still connected, I have redone all the ground wires, removed the ecu to test, connected the distributor to direct power but nothing works. Still no spark from the coil. I get power to the Ignition module and coil but no spark at coil.
Any ideas please?
My Cluster also does not work, only the indicators and hazards comes on.
All fuses checks ok.
Old May 26, 2023 | 03:30 AM
Edward94's Avatar
Default Re: 1992 Honda Civic LX / Ballade luxline 1.5 NO Spark issue, carburetor conversion.
Bump
dog2525
12
Mar 4, 2013 12:18 PM
gizmo jdm
Nov 14, 2011 04:29 AM
kenwolf
Nov 21, 2010 02:06 PM
ex_ricer
Aug 14, 2008 02:14 PM
CptCorN
Jan 17, 2005 06:33 AM
