Cranks no start no fuel pressure and scanner has linkage error need help
Old May 16, 2023 | 07:04 PM
bagurto110204's Avatar
Default Cranks no start no fuel pressure and scanner has linkage error need help
I have a 1997 ek hatch swapped everything I had on my 1999 ek coupe dx into it and I have been having trouble with the car starting ever since wondering if someone could help me? I swapped engine a D16Y7, manual transmission, and both engine harness and the harness that’s behind the dash. It’s cranks but doesn’t start, no fuel pressure, and my check engine light is on. I’ve checked all grounds are good, checked all fuses and none are blown, changed main relay all being OBD2B (The main relay does click once I turn the ignition) and I have corrected the wires that are plugged to the ECU which came from the 1999 civic. I have plugged in a OBD2 scanner and it always says linkage error. Any ideas what my issue could be?
One thing I forgot to mention is that when I was swapping the harness that is behind the dash I had to de-pin two connectors and I’m wondering if that could be it but I also doubt it
Old May 17, 2023 | 02:53 PM
spAdam's Avatar
Loved
Community Favorite
Default Re: Cranks no start no fuel pressure and scanner has linkage error need help
You can't run a 99-00 ecu in a 96-97 Civic. The pinouts are significantly different.
mikespenny
Jan 12, 2014 06:43 PM
honda_hackett
Nov 3, 2008 03:56 PM
boostincoupe
Acura TL, RL & ZDX
Jul 3, 2006 06:03 PM
