JDM B18B Intake Air Temp Question
Old May 14, 2023 | 04:57 PM
Ashz_ED8's Avatar
Default JDM B18B Intake Air Temp Question
Long story short, I have the JDM B18B with the IAT mounted onto the intake tubing rather than the manifold. I had the original sensor when I first got the motor (non-screw hole sensor) but no longer have it. I have it ghetto rigged currently with the normal 2 screw hole IAT shoved into the tubing hole with a hose clamp but I’m looking to change it to the normal one. I can’t find one listed for an Integra. However the 96-2000 civic ones look exactly the same and I’m wondering if I can use it? They’re both 2 wire so it should wire in fine. But would the actual reading to the ecu be different or would it be the same ? I know I can switch to a usdm manifold but I’d like to try a simpler and cheaper way first. Sorry for no pics, it’s not loading for whatever reason.
Old May 14, 2023 | 06:37 PM
Ashz_ED8's Avatar
Default Re: JDM B18B Intake Air Temp Question
Old May 14, 2023 | 07:46 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You cannot find one for an Integra because all Integras came with the two screw one in the intake manifold and NOT the one in the intake tube. Use the EK Civic ('96-00) sensor if you intend to run the IAT sensor in the intake tube.
FYI, if you are using a USDM ECU, it operates BETTER if you use the 2-bolt sensor screwed into the intake manifold. The intake tube sensor doesn't vary in value nearly enough for optimum performance with ANY Integra ECU. So the question that you have to ask yourself is: Do I want to fix this correctly or do what is easy ?
Old May 14, 2023 | 07:48 PM
Ashz_ED8's Avatar
Gotchu. Appreciate the response, didn’t actually know that 👍🏼 looks like I’ll be switching up the manifolds.
b_serious
Oct 15, 2005 06:37 PM
rasinhell
Aug 15, 2005 02:50 AM
rasinhell
Jul 31, 2005 07:24 PM
NixTEG
Dec 24, 2003 03:05 PM
89JDMcrx
Aug 4, 2003 06:08 PM
