Electrical issue 2000 Honda Accord mt
Old May 8, 2023 | 07:12 PM
masterswordsmen's Avatar
Default Electrical issue 2000 Honda Accord mt
So, goes without saying, I blew it. I changed my shift cable, and while doing so, pulled out the wiring from the vss wiring harness. Not a big deal, but when I reconnected the wires, the speedometer wasn't working, so i thought maybe it connected the wrong wires, and switched some wires around which was dumb. So I fried something, but want to know where to start looking. I've got a few engine codes, po1298 (electrical load detector), and po135/141 (o2 sensor heater circuit bank 1 sensor 1&2). All door ajar lights come on, including trunk and brake lamp lights. The car starts and runs, but I'm not sure where to start on diagnosis: ecm? Fuses/relays? Vss harness? Any insights would be greatly appreciated!
Old May 8, 2023 | 07:24 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Electrical issue 2000 Honda Accord mt
Driver's side under-dash Fuse No. 6 (15A) is probably blown.
Fuse No. 6 protects:
Charging system, Cruise control, Engine mount
control system, Evaporative emission control system,
Fuel and emissions, Gauge assembly, Radiator fan
control module (V6), VSS (M/T)
Old May 8, 2023 | 08:11 PM
Yes, the fuse you mentioned was indeed blown. Thank you! I will need to get a new one and replace it.
Ravenous117
10
Mar 20, 2015 12:03 PM
tr6lover
Apr 20, 2014 09:10 AM
97VtecIN
Nov 13, 2004 12:36 AM
Federic0
Audio / Security / Video
Jan 13, 2004 03:28 PM
