Stuck in 4th gear
Old May 4, 2023 | 07:59 PM
Jlizama01's Avatar
Default Stuck in 4th gear
I have a 92 civic-swapped a b20 into it a while ago, after a while of driving the car one day I was cruising and I hear a loud smack or bang almost and then I realized it was stuck in gear.
I recently pulled the clutch, it wasn’t in the best condition and 2 of the springs were loose so I replaced it with a stage 1- new flywheel, clutch & pressure plate. Still nothing, it’s stuck in gear and even when it feels like I’m in neutral, if I let go of the clutch it’ll stall.
Not sure what else to do, has anyone had this issue?
Old May 5, 2023 | 08:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Stuck in 4th gear
It is possible that the selector tooth on the shift change piece has broken off... leaving you in the last gear that you were in at the time.
ohsnapzafingcu
Nov 14, 2009 10:28 AM
JDMhondalude22
Oct 4, 2006 11:12 AM
eMpAtHy
Apr 18, 2005 12:39 AM
