Obd1 engine in obd2 car
Old May 3, 2023 | 05:37 PM
ej8.Brian's Avatar
Default Obd1 engine in obd2 car
I recently bought a b16 swapped 2000 civic ex. How would I get this to pass inspection. I bought a p2t ecu but it throws Cel’s. What would I need to convert/bypass to get the cel’s to go away at least for inspection? (Sorry if this has been asked, I couldn’t find any answers)
Old May 3, 2023 | 08:07 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Obd1 engine in obd2 car
What codes do you have ?
Old May 4, 2023 | 07:11 AM
ej8.Brian's Avatar
p1259.
Old May 4, 2023 | 07:44 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Make sure that your VTEC solenoid is plugged in. If you have a JDM B16A, your VTEC assembly may not have a pressure switch, which is required for proper operation with the P2T ECU. You will either have to drill and tap the port on the JDM VTEC assembly and purchase a pressure switch from your local Honda dealership (one from a '92-00 Civic EX or Si will work just fine), install it and plug your engine harness into it. Clear the code and you should be fine.
Old May 5, 2023 | 05:30 AM
ej8.Brian's Avatar
ok thanks I just bought a usdm solenoid so I don’t have to drill anything
Old May 5, 2023 | 08:57 PM
JRCivic1's Avatar
10 Year Member
Community Builder
That works too.
mariog96teg
Dec 12, 2013 10:03 PM
GS-Racer X
Engine Management and Tuning
Jul 16, 2009 06:17 PM
bflan2001
Oct 19, 2006 03:49 PM
PhatHardy
Jul 21, 2003 06:41 AM
