hard to throw a jdm vtec int 4 gen si??
i went from f22 to jdm h22a also, but i had problems because i used the regular s harness...i had bogging problems at the low end....i fixed that problem with a chipped p28 ecu...so if you decide to go that route...to use the stock wire harness..then i suggest a p28...the stock p13 kept throwing codes
