Replace bushings or complete control arm?
Old May 3, 2023 | 07:23 AM
Farquea's Avatar
5 Year Member
Default Replace bushings or complete control arm?
I had my car serviced this week and was informed that the bushings are on their way out on my left rear lower control arm. I'm just curious if I should just replace the bushings or do the entire control arm instead. Any pros and cons to either?
Old May 3, 2023 | 11:26 AM
kraquepype's Avatar
10 Year Member
Default Re: Replace bushings or complete control arm?
It would be cheaper and less wasteful if you can find the bushings you need, and have a press to remove / install them.
You have more options when it comes to complete control arms, but you'd have to do both sides.
Old May 5, 2023 | 06:00 PM
Tyson's Avatar
It's a lot easier and better to just get new arms with new bushings already pressed.
Highly recommend that.
And don't use poly. Downgrade compared to rubber.
beefystud
Mar 1, 2017 03:13 PM
decode33
Honda CR-V & Element
Oct 29, 2011 06:48 AM
kornerk12
Aug 3, 2008 09:10 AM
94vtirozguy
Apr 14, 2006 11:37 PM
