Freshly rebuilt d16z6 question...
Old Apr 25, 2023 | 08:03 PM
POLISHpickles's Avatar
Default Freshly rebuilt d16z6 question...
Hey guys, Ive been trying to find anything online but no dice...
Just finished my build and would like to crank her over a bunch of times without fuel or spark, to lubricate the internals.
Some would say "just send it", but I aint that kind of car owner. Werd to your mother.
What is necessary to disconnect to make this happen?
Thanks in advance guys!
Old Apr 25, 2023 | 08:32 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Freshly rebuilt d16z6 question...
Pull the 15A and 7.5A ECU and Back-Up fuses in the under hood fuse box. They are the two fuses closest to the firewall and right fender. You can then crank the engine without spark or fuel delivery.
Old Apr 25, 2023 | 09:15 PM
Thank you for your wisdom brother👊
Old Apr 26, 2023 | 05:14 PM
crazyhorse2011's Avatar
10 Year Member
Loved
pull plug off ignition coil, pull connector off fuel rail. 5 seconds to do and no tools.
Old Apr 26, 2023 | 09:13 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I assume you mean "Unplug the distributor" here, but I am not sure what you are referring to in the second part of your statement. As for tools, it is likely that none are needed to pull a couple of full sized blade fuses, unless you have sausage fingers and cannot grab them. LOL In that case, you would need a pair of needle nosed pliers or a fuse puller.
Coleman944
26
Oct 30, 2013 08:49 AM
vtec4max
Oct 26, 2009 05:28 PM
lowbOOsted
Sep 18, 2005 10:09 PM
Btothe3rdDegree
Sep 10, 2004 06:17 AM
