Swapping to Smaller Turbo
Old Apr 20, 2023 | 04:49 PM
ThatGuyWithArms's Avatar
Default Swapping to Smaller Turbo
Hello all!
New to Hondas and modifying FI setups. Car is a '91 hatch. d16y7 bottom, d15b head. Chipped p28 running on HTS. Current 60/62 turbo setup made 298whp on the dyno. I want to swap to a smaller turbo and work on making this thing a response monster for autoX, with occasional HPDE days. Is changing to a smaller turbo as simple as selecting the one that fits my goals and then tossing it on (only talking about physical parts needed to swap - NOT taking into account re-tune)? May need new oil feed/drain adaptors or similar but is there anything I'm missing?
Old Apr 21, 2023 | 10:17 AM
ls joker's Avatar
Loved
Default Re: Swapping to Smaller Turbo
Originally Posted by ThatGuyWithArms
Hello all!
It may be that simple if you purchase one that has the same style exhaust housing. But there still may be alignment issues. Chances are it will be fine. CHRA fittings may be different aswell. You will need to do your homework on what type and thread fitting it calls for.
Old Apr 21, 2023 | 12:17 PM
Ah, good point. If I go to a smaller turbo, should I also be looking at porting the wastegate or potentially installing restrictor plates downstream to prevent overboost?
GatorGuard
Apr 19, 2022 08:46 PM
BurnsyEP3
Dec 8, 2013 05:52 PM
ticaaal70
Aug 18, 2010 08:38 AM
hondaEg_808
May 21, 2010 09:53 PM
ej1252
Oct 30, 2007 01:51 PM
