Minimal Stereo Setup?
Old Apr 19, 2023 | 05:41 PM
mattkosem's Avatar
Default Minimal Stereo Setup?
Hey All,
Long time no post. My EG's mostly doing track duty these days, and I need to remove the radio to fit gauges but don't wanna lose sound entirely since it does also see some road time and I drive it to/from the tracks. I picked up some things to make it work, but am curious about what others have done.
My plan is to stick one of these guys in the cigarette lighter hole:
Amazon Amazon
I got a crummy little amp to stuff behind the current stereo opening:
Amazon Amazon
Has anyone done anything similar? What did you do and how do you like it? I was trying to do something totally headless but having no physical control at all ended up being a problem in my local out-of-car testing (dangerous volume/track adjustments, unpredictable volume levels, etc.).
--Matt
Old Apr 20, 2023 | 05:28 AM
AydenA20's Avatar
5 Year Member
Default Re: Minimal Stereo Setup?
Have you looked into the JDI ghost box?
Old Apr 20, 2023 | 09:03 AM
mattkosem's Avatar
No, but it has the same downsides as the other BT with no physical controls I evaluated. It's dangerous to be fiddling with a phone to skip songs and adjust the volume, and I found the volume level after connecting/reconnecting to be unpredictable at times.
--Matt
Old Apr 20, 2023 | 06:57 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
What I used to do when I had no BT radio is just stick a JBL Flip 4 in the gauge cluster area. It projected the sound towards me the best from there. It has physical buttons if you need to raise/lower/pause. A 92-95 civic gauge cluster might not be deep enough, but some velcro strips might also solve that problem. Plus, it’s removable.
If you don’t want that, the simplest solution is going to be a headunit relocation if you have space.
Given that lower consoles for 92-95 civics are probably worth more than the car, it may be easier to just hard mount a stereo somewhere or fab a housing for it that mounts to the tunnel.
Or just be like all the other dorks today and drive around with headphones in
Old Apr 21, 2023 | 06:33 PM
mattkosem's Avatar
Got everything wired up an installed. The NXT thing seems like a sure thing. Fits right where the cigarette lighter goes and provides enough control.
That Pyle amp...needs to go. Has a nasty hum at low input volumes and generally sounds crap. All in all, I'm gonna call it a win for now!
--Matt
Old Apr 25, 2023 | 04:18 PM
mattkosem's Avatar
Swapped out the amp with one of these: https://a.co/d/cgHeMwH
Much better! 😎 So tiny also!
-Matt​​​​​
nightscream
Audio / Security / Video
11
Jul 3, 2011 06:31 PM
Del Namco Solo
Nov 19, 2010 03:02 PM
Monaco
May 14, 2007 11:44 AM
blackEuro-R
15
Jan 11, 2007 04:31 PM
projectDx
Oct 26, 2004 05:21 PM
