Rear brake bleeding: no fluid comes out when using power bleeder
Old Apr 16, 2023 | 07:10 AM
vwdirector's Avatar
Default Rear brake bleeding: no fluid comes out when using power bleeder
Hi, i’m trying to bleed my rear brakes with a power bleeder, but my rear right caliper does not have any fluid coming out of it. I removed the rubber line, and I do not see the fluid coming out of the hard line. Any suggestions when it might be?
I bled the left caliper with no issue.
Old Apr 18, 2023 | 01:16 PM
LukeM's Avatar
5 Year Member
Default Re: Rear brake bleeding: no fluid comes out when using power bleeder
Might be clogged. Punch a pipe cleaner up it.
Old May 4, 2023 | 06:24 PM
vwdirector's Avatar
Update: I changed the proportioning valve, but I am still not getting fluid in the rear brake caliper. I’m thinking it is the ABS pump?
Old May 6, 2023 | 01:31 PM
LukeM's Avatar
5 Year Member
ABS and brakes are separate systems so they won't affect each other. It is also highly unlikely your ABS still works after all these years.
Old May 7, 2023 | 03:20 PM
vwdirector's Avatar
Thanks for the input. Maybe it’s the brake master cylinder?
Old May 7, 2023 | 06:24 PM
LukeM's Avatar
5 Year Member
If the car was stopping properly the MC is working fine. The problem is with the line. Maybe it's blocked inside or kinked. Trace it out and see what you find
Old May 22, 2023 | 06:22 AM
vwdirector's Avatar
Update: fixed the issue by doing an abs delete. I used the Valex racing kit.
nycpatron
Sep 6, 2016 06:58 AM
CBL9
May 11, 2012 01:32 PM
D16SiHatch
11
Apr 28, 2011 08:00 PM
jdmboy96
Feb 10, 2009 08:44 PM
DJ0820
Apr 28, 2004 11:12 AM
