Fuel pump not priming
Old Apr 13, 2023 | 09:00 PM
Andy_97ek's Avatar
Default Fuel pump not priming
I'm trying to jump my main relay with a paper clip but I'm having trouble understanding where to put the paper clip because I'm trying to figure out if i need a new main relay because my fuel pump isn't priming
Old Apr 15, 2023 | 10:00 AM
Maxcapacity's Avatar
Default Re: Fuel pump not priming
Something easy to do and I've probably said this quite a few times but, if you have a good camera on your phone or whatever, take a picture of the solder points of the main relay circuit board and zoom in. Looking for any that have a fine dark ring going around the solder of a point. If you see any, re-melt the solder because those are cracks which can cause the problem and doing this saves you from buying another relay.
Old Apr 22, 2023 | 03:14 PM
countrynoob's Avatar
From: Whats Up MN!! But still the middle of nowhere...
92-95 (under driver side)
96-99 (under passenger side)
Old Apr 22, 2023 | 03:19 PM
You would have to take the main relay out and test it by applying power and ground to the respective signal sides and then with a voltmeter check for continuity on the switched sides.
Justin42
Sep 12, 2022 09:37 AM
si 1
Dec 21, 2005 11:03 AM
RCSIVTEC
May 12, 2002 10:14 PM
